Old 07-30-2011, 04:15 PM
Question How to clean bare aluminum?
My plane is dirty. Just finished Phase One it was intensive flying. To clean windshield and cowling was easy but bare alclad I didn't touch yet. Flown through a rain for a brief period and there are streaks everywhere it looks not nice. How do you clean yours unpainted? Could I use avgas to clean oily underneath?
Old 07-30-2011, 04:23 PM
curtis's Avatar
curtis curtis is offline
I keep a spray bottle with water and a few drops of Dawn dish soap in the hangar. After each flight I spray the leading edges, cowling, prop, and canopy to clean the bugs off. Note: I do not use the same towel for the canopy that I use on all of the other surfaces. I use a microfiber towel on the canopy.
RV-6A Slider
550 hours +
Build it light and cheap
Old 07-30-2011, 04:31 PM
scard's Avatar
scard scard is offline
Tanya cleans the oily under side of her airplane exclusively with avgas. She has tried all kinds of stuff but likes avgas the best. She just recently (after 4yrs) got herself a creaper and has seen the light! I've been telling her that she needed one for four years .
Scott Card
CMW E-Lift
Vern's Avatar
Vern Vern is offline
Default Cleaning Aluminum
I worked in an aluminum extrusion plant years ago. We kept lacquer thinner on each workbench.
I still use it. Keep it off painted surfaces though.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 07-30-2011, 05:12 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Spray bottle with mineral spirits.
Wipe with a rag you plan to throw away---------or at least take to the laundromat to clean, dont wash in your own machine
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-30-2011, 07:28 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Highly unlikely to explode unless of course it has a source of ignition... Please use mineral spirits instead... OK, so call me an old fuddy-duddy...
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 07-30-2011, 09:09 PM
flion's Avatar
flion flion is offline
I'm not a big fan of mineral spirits; it tends to smear and streak. And avgas can stain (it has dye in it, albeit not much). Simple Green is good for getting the tough stuff off the bottom, soap is Ok for the rest. I've been afraid to use it on my plane since I do intend (someday) to get it painted but I use Pledge on my bike to remove bugs from the chrome; it also helps to make future bugs easier to remove. If you are going to paint, be very cautious what you put on your plane; even overspray of some canopy cleaners.
EAA Technical Counselor #5357
Old 07-30-2011, 09:30 PM
Snowflake's Avatar
Patrick, I've been told that Pledge has silicones in it... Keep it off your bare aluminum if you're thinking of painting later.
Rob Prior
Old 07-30-2011, 09:38 PM
DENMACRES DENMACRES is offline
Smile CLEANER
I USE A CHEAP PRODUCT CALLED AWESOME, AVAILABLE A 99cent or dollar stores. Be sure to dilute it.
Old 07-31-2011, 07:24 AM
tkatc's Avatar
tkatc tkatc is offline
For the leading edges, just water and bug sponge.
For the belly, Simple Green, Boeing spec. KGB approved.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
