Old 05-03-2006, 07:29 AM
N941WR's Avatar
N941WR N941WR is offline
Default 3M? Fire Barrier Caulk CP 25 WB+
Do any of you have experiance with 3M? Fire Barrier Caulk CP 25 WB+?
A friend who is building a Murphy Supper Rebel recommended it but I can't find any reference to in the homebuilding forums I have checked.
"Up to 4 hours Fire Protection." sounds good to me.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-03-2006, 09:51 AM
TerryPancake TerryPancake is offline
Good Morning Bill. I don't know if I'll be in my RV 4 hours even if it's not on fire....
Terry W.
RV-7 QB
Emp Done. Fuse and Wings in the Garage.
N825TW reserved
Old 05-03-2006, 11:08 AM
thallock thallock is offline
Bill,
There's no information on what temperature it can withstand. This product appears to be for housing construction. We've seen this discussion before on products that you could buy from Home Depot/Lowes, and they do not meet the 2000 degree requirement for an aircraft.
Why don't you contact 3M and find out what it's specs are, and let us know.
Tracy.
Old 05-03-2006, 04:34 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Codes
If it's rated for a 4 hour fire protection rating (seems to be from the 3M data sheet), then it won't burn through at 2000F ... per the NFPA codes....
Testing details here....
http://www.klsecurity.com/ul_fire_rating.htm
gil in Tucson
Old 05-03-2006, 04:52 PM
Gil,
Thanks for the info. That would make it acceptable for FW penetration sealant. However, at $185 for 10 oz, that would make it three times as expensive as the sealant that Van sells:
http://www.vansaircraft.com/cgi-bin/...product=cs1900
Always looking for something that we can seal the holes in the FW without spending a fortune.
Tracy.
Old 05-03-2006, 10:39 PM
az_gila's Avatar
Exclamation $$$$
Whoaa...
Didn't see the $185 bit!!
gil
Old 05-03-2006, 11:32 PM
rv72004 rv72004 is offline
Glasair uses this product. Excellent .It also expands in a fire to offer better sealing of joints/holes.
I paid $30 for a tube . You dispense it with a standard silicone gun dispenser.
