Old 07-30-2011, 07:48 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default Thank you for coming by @ KOSH
I would like to thank everybody that came to my ignition presentation and also stopped by Russ’s supercharged 7. I look forward to seeing the group at the next event…Larry Vetterman’s fly-in coming up in early September.
Thomas S.
Thomas Shpakow
http://www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
Old 07-30-2011, 04:46 PM
Fearless's Avatar
Fearless Fearless is offline
No - thank you for putting on the presentation. I liked the mock-up you created for the presentation. I could see the difference in the spark at the plugs with the ignition energized. I worked on the plane today to install my G3 module above the rudder pedals under the forward top skin. I used nutplates on my mounting brackets so I can remove the unit for service if need be. Hopefully I'll get this plane flying at some point so I can visit you guys out West.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
