Old 07-29-2011, 09:51 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Question Sky Charts Pro Question?
Hi guys we are at OSH and have access to a slow wireless connection. We started the Chart up date for our flight back home on Sunday and seem to be caught in a continuous loop where we are 90% down loaded but now it just sits then stuck in the down load and wont finish. Even if we end the program when we start it again it goes right to this download again. How can we stop this down load without deleting the the program?
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 07-29-2011, 10:34 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Same problem with ours also.
I would like to see a description of what is happening, in addition to the status bar--------
Home now, hopefully it will download correctly with the home network.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-30-2011, 01:22 AM
tkatc's Avatar
tkatc tkatc is offline
John,
I think you just need a faster connection. When I do my updates I usually let it run overnight while plugged in. You could also try selecting/deselecting only the areas you need to get home. Hope it works out!
Nice looking 12! I followed you into OSH and was parked right next to you until Thurs.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 07-30-2011, 05:41 AM
Jetguy's Avatar
Default Update
After leaving the Ipad in the window all night on the 6th floor we woke to a completed update so we are good to go on Sunday. Thanks for the help
John
RV12 N1212K
Johnrv12@icloud.com
S/N 140014
Old 07-31-2011, 05:36 PM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Updates
I updated SCP on my iPad yesterday and it was pretty quick, just as fast as my WingX Pro updates. I have Uverse at 12mbps.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
