Old 07-28-2011, 04:53 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Spinning rivnut's
I have a few spinning rivnut's that hold fairings on. In some areas I cannot access the back of the rivnut. If I purchase a rivnut tool can I re-seat them to keep them from spinning?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 07-28-2011, 07:08 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Rivnuts
You could try the tool as a first step. It may or may not be successful.
If that doesn't work, drill them out carefully while holding the lip with a pair of vice grips or pliars and replace them with new ones.
The rivnuts with the tabs will prevent that from occurring in the future.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 07-28-2011, 07:54 PM
aerhed aerhed is offline
Like Don said. Keyed rivnuts with the right grip length & hole size are best defense. If your holes are too big, maybe you can set nutplates with the flush -3 pop rivets by drilling the leg holes from the outside and slot the hole just enought to weasel in a -06 nutplate. Maybe won't show under a fairing?
Actual repeat offender.
Old 07-28-2011, 08:08 PM
molson309 molson309 is offline
If the area isn't completely sealed on the backside - i.e. you can put a piece of safety wire through the hole from the outside and find it on the inside - you can install a nutplate. Drill the holes for the ears and countersink them for 3/32" flush pop rivets. Push a piece of safety wire through the middle hole, and string a nutplate on the wire on the inside, then bend the wire end over so you can then pull the wire back and get the nutplate up against the inside. Rotate the wire to get the holes aligned, pop rivet it into place, and then pull the safety wire out. Done!
I have used rivnuts in a few places on the -7a, but I have had several spin on me. It seems like you need a minimum thickness of the skin to really retain these things or you risk spinning them in the hole. The tab mounted ones no doubt work better, but I really like nutplates and use them wherever I can.
Mark Olson RV-7A F1-EVO Rocket
Old 07-28-2011, 08:52 PM
bruceh's Avatar
bruceh bruceh is online now
How about some epoxy or JB weld to make them stop spinning?
Bruce Hill
2020 VAF donator
Old 07-30-2011, 08:30 AM
GAHco's Avatar
GAHco GAHco is offline
Talking Loctite?
Try wicking a little of a higher strength Loctite from the outside where the head meets the structure. A day or so later and you should be able to put your tool in and re-compress (ever so slightly) the rivnut body.
I've done it before on certified planes, and unless the rivnut is trashed you should get good results.
Best Wishes for your success!
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 07-31-2011, 07:05 PM
ccsmith51's Avatar
Default Thanks...
for all the suggestions. I'll buy a rivnut tool and try some or all of the suggestions, depending on the situation.
Chris Smith
Old 07-31-2011, 08:00 PM
N941WR's Avatar
N941WR N941WR is offline
Chris, go the the 11/12/08 entry of this page of my web site. (It's the last entry.)
That tool works very well, if you use a cordless drill to set the rivnuts and doesn't cost that much.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
