07-26-2011, 10:33 PM
Crossing the pond in an RV
I'm hoping to do this in a couple of years time and have been gleaning information for some time.
One concern seems to be that when getting permission to fly non 'standard category' aircraft in other countries, that permission is usually day/VFR only.
Although I'd only set off in good weather on each leg, the chances of remaining in VMC for a whole atlantic crossing must be slim to say the least. It's made worse by being forced to 5500' or less because the NAT controlled airspace starts at 6000' and requires an IFR flight plan.
That would also mean poor VHF range, reduced efficiency and the inability to fly over a cloud layer.
I know several homebuilts have done the crossing. So how did they do it? Are there exceptions to the VFR limitation? Is it worth upgrading the kit to meet TC's more rigorous IFR requirements if you're forced to be VFR only?
I'd be especially glad to hear from anyone with practical experience of this.
07-27-2011, 03:19 AM
Ring the master
Mark,
go to this website,
http://www.flymore.com.au/contact.html
punch in his number and have a chat. Jon is a great guy and will talk your ear off about everything you need.
You will learn about what real approaches are used internationally, how prepared you need to be for ditching and water egress and even just some common sense flying.
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
07-27-2011, 10:32 AM
If you leave from Canada I believe an IFR rating is needed -
Section 39 here -
http://www.tc.gc.ca/eng/civilaviatio...6-602-2436.htm
A friend crossed the other direction in a Mooney - said he'd never do it again...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
07-27-2011, 11:32 AM
Thanks, yes I understand that.
I see from the standard validation that Canada gives for US homebuilts, that IFR is permitted, if allowed by the US operating limitations and equipped according to CARs or CFR pt91.205
So that leaves Greenland, Iceland and UK requirements to sort out.
I suspect an IFR certified GPS or ADF will be needed to stay legal.
07-27-2011, 12:29 PM
Mark, just before leaving Australia I ran across an article on an Aussie who's done two Circles in his RV (a -4, if memory serves) so it can certainly be done. (He was about to begin his third...).
Sorry I don't remember his name but a great group of guys/gals to contact and get a referral from can be found here:
www.recreationalflying.com.au
Jack
07-27-2011, 12:38 PM
Jack,
That's Jon Johansson.
I've got his book "Aiming High".
It gives a good background, but doesn't cover all the fine detail.
Jon chose to get to Europe via the Azores, that needs HF radio and lots of fuel!
07-27-2011, 01:05 PM
Lots of fuel!
Yeah, 18 hours worth
Van gave him a letter of approval for 300 lbs of fuel in the back seat, since the authorities wanted it. Jon had gradually put more and more load back there and safely landed with 300 lbs back there, plus his wingtips for 18 hours total! When he told Van about how he incrementally loaded it, he was satisfied that Jon went about it properly.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
07-27-2011, 01:34 PM
I'm still debating whether standard fuel would do it.
The critical leg is West to East of Greenland - only 340NM and can legally be done VFR, but no alternates to Kulusuk. Your only other options are turn back or continue another 380nm to Iceland. So 800NM is about the absolute minimum range.
Does anyone know a best range for an -8; Carson speed, LOP, electronic ignition? Obviously, I'll need to establish that but my guess would be around 130 KTAS and 6 Gall/hour giving just over 900 NM on 42 Galls.
07-27-2011, 10:17 PM
I was told a while ago that you couldn't do it as a Private Pilot anymore... You had to have a Commercial license. I haven't looked into enough regs to know if this is true, but it would be worth looking up.
Rob Prior
07-28-2011, 01:13 AM
Doesn' look like it...
Transoceanic Flight
602.39 No pilot-in-command of a single-engined aircraft, or of a multi-engined aircraft that would be unable to maintain flight in the event of the failure of any engine, shall commence a flight that will leave Canadian Domestic Airspace and enter airspace over the high seas unless
(a) the pilot-in-command holds a pilot licence endorsed with an instrument rating;
Gil Alexander
