Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #11
Old 07-28-2011, 06:40 PM
FAF FAF is offline
Default P-Mag timing
Talked to Brad today and performing his checks to first see if the P-Mag was getting power-they were. Then installed a jumper wire from the ground terminal to the p-lead/kill terminal to see if that gave the red led-it did so the problem was the p-lead/kill switch was not grounded. I have my P-Mags wired as per the wiring diagram on their instructions with 4 switches and using single pole switch with the three lugs on the back. I had the wire from the P-Mag going to the bottom lug and the ground wire was attached to the middle lug. Had to change it to the ground wire to the top lug and P-Mag wire to the middle lug and that gave me the red led light. I then was able to time the mags as per the instructions. Thanks everyone for the help. Frank
