Old 07-25-2011, 07:29 PM
stickandrudder1 stickandrudder1 is offline
Default GTN 650 Power Requirements
Can anyone tell me the power requirements of the GTN 650. I've looked around everywhere on the internet and cannot find an installation manual for the 650. Garmin doesn't make it available online. I guess a good estimate would be the figures for the 430W.
RV7A - Completed and Flying Since March 2019
Old 07-27-2011, 08:01 PM
MCA's Avatar
MCA MCA is offline
I just installed one. They have different specs for 14 and 28v systems, but assuming 14v then the comm circuit is 10A breaker and the nav/main circuit is 7.5A breaker. Your dealer should make the harness itself for you.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 07-27-2011, 08:30 PM
TX7A TX7A is offline
Marc,
Would you happen to know the "sustained amps" for the 650?
I guess that would be the NAV & GPS receiving and the COMM mic keyed.
Thanks much!
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 07-28-2011, 08:56 PM
Default And the Answer is:
14V
Main Connector 1.6A Typical 2.8A Max
Comm Connector .45A Typical 5.66A Max (16Watt) 4.02A (10Watt)
Nav Connector .6A Typical 1.16A Max
28 V
Main Connector .8A Typical 1.5A Max
Comm Connector .21A Typical 2.33A Max(16 Watt) 1.76A (10 Watt)
Nav Connector .3A Typical .58A Max
Old 07-28-2011, 10:05 PM
Originally Posted by stickandrudder1 View Post
14V
28 V
Nav Connector .3A Typical .58A Typical
Hey, thanks! Mr. S&R
Sam Evans
RV7-A O-360 C/S
VAF#812
