Old 07-25-2011, 10:49 AM
paulincapetown paulincapetown is offline
Default Slider canopy with tilt and quick lift-off features
Does anyone know where I can find out more about these canopies and what is the general perception of them. Are they any good and or are they diffucilt to install?
Regards
Paul
Old 07-25-2011, 11:26 AM
Vern's Avatar
Vern Vern is offline
Default Canopy tilt
I'm assuming you mean for the 6,7,9?
Simple to install and use.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 07-25-2011, 11:44 AM
pierre smith's Avatar
Default Yep
Paul, all they do is grind away the sides of the rail on top, so that the nylon block can lift off, when the canopy is roughly half way back. Fit struts of some sort to hold it open. Can't think of the vendor's name right now but the canopy has to be far enough back so that it doesn't hit the top of the windshield when you open it.
Here ya go: http://www.aircraftextras.com/
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-25-2011, 01:01 PM
Thanks Pierre
Will investigate further. My new RV7 kit arrives September/Oct in Krugersdorp so have a bit of time to sort this out
Regards from a cold Cape Town
Old 07-25-2011, 03:03 PM
kbehrent's Avatar
kbehrent kbehrent is offline
Default 2 thumbs up for Meske mod
I have the "Meske" mod installed on my 9A and I really like. It makes it easy to fully access the baggage area and along with the custom hat shelf installed behind the baggage compartment upper bulkhead for light weight items such as coats, pillows, sleeping bags, etc. The upper baggage panel uses piano hinges and the screws were replaced with "butterfly" style locks that some use for their oil door. (Sorry, forgot what their called )
Getting access to the hat shelf would have been extremely difficult without the mod, which was one of the reasons I installed it.
I know there are a couple of others now, but Meske mod worked good for me.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Old 07-25-2011, 07:08 PM
RV7ator RV7ator is offline
Paul,
You don't need to buy anything. Notch the deck rails about 11 1/2 inches aft of the roll bar, and notch the guide rail where the slider block winds up so it can be lifted free. Install a drawer pull (handle) on the aft end of the center canopy bow as a grip. Use a piece of 3/16" piano wire as a support strut between the canopy and a hole drilled into the pin block. To lift off the canopy, pop out the two bolts joining forward canopy bow and the rollers and hoist it away. (You don't need nuts on these bolts for flight. Impossible for them to move forward.)
It's a really useful mod. Makes baggage access trivial compared to no tip/remove.
John Siebold
Old 07-25-2011, 08:13 PM
qtrmiledan qtrmiledan is offline
Default canopy mod
John Could you post some pix of the piano wire struts? Thanks!!
Danny B
Baker,La.
RV9A #91137 Flying!!
Old 07-26-2011, 04:49 AM
As I have just paid for my RV7 (ouch) I don't have much mola left.
I like RV7ator's suggestion so will check this out
