Old 07-24-2011, 10:42 PM
N131RV N131RV is offline
Default Looking to replace Skytec
I've had a Skytec starter on my bird since the beginning, but I'm tired of being "surprised" and stranded at foreign airports when it craps out unexpectedly.
For some reason, my bird eats Skytecs. I've put a total of four of them on (the same two rebuilt twice) over the last year and a half. This last time takes the cake, I was carrying a spare starter, since I was so gunshy.
Three weeks ago the main starter crapped out again (solenoid went bad). I put on the spare and flew home. Friday, with less than ten hours on the rebuilt starter, it crapped out and left me stranded in Houston.
Again, the (looks to be cheaply made) solenoid crapped out. The little metal plate that holds the hot lug was loose to the touch. Wiggling it would make the starter fire (if power was applied), but no way to do that with the cowl in place. This has been the case three of the four times. The metal holding the "hot" lug becomes loose and the starter becomes intermittent, then quits altogether.
So, suggestions are welcome. I'm looking at Kelly (now Hartzell) but any suggestion would be good.
JP
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 07-24-2011, 11:07 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Default B&C
http://www.bandc.biz/index.aspx They make good stuff!
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 07-24-2011, 11:19 PM
NeilMcLeod NeilMcLeod is offline
Default Starter Replacement
My skytec literally fell apart. Replaced it with a Kelly and I'm very happy so far.
Neil McLeod
Sierra Vista, AZ
RV-7 N748M (sold)
Slider
Aerosport IO-360 B1B
MT-MTV 15B-C/C Acro 2 Blade
Inverted fuel and oil
Trutrak EFIS GP AP 2
2014 Dues Paid
Old 07-25-2011, 04:30 AM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default B&C
I too had problems with my skytec starter. I replace it with a B and C starter and have had no problems since.
I sold my problematic Skytec to a friend whom had it rebuilt again and it has lived on his 9A for almost 1000 hours without any problems.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 07-25-2011, 05:15 AM
N282S's Avatar
N282S N282S is offline
Default me too
The front housing which holds the front bearing that carries the solenoid fell apart. I've seen some forum threads where this is a common break on the lightweight series. I replaced mine with the skytech "NL" series which is there heavy duty starter. A couple more pounds but a lot less worries.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
Old 07-25-2011, 05:37 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default more
My RV-7 friend had his Skytec lightweight just quit the other day, we took it to the local rebuilder to be fixed. When I picked it up, he told me it looked like it was wired by a 10 year old. He thought it was junk. He did go though it and repaired it and it now works just fine.
Just one suggestion would be to have your starters checked over locally so you can have a little more faith in them. Was 100 to have it fixed.
Good Luck.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 07-25-2011, 05:47 AM
BlndRvtr BlndRvtr is offline
I've been very pleased with my B&C. 500 hrs, about 375 starts, not a glitch.
George
Old 07-25-2011, 09:55 AM
Default How many starts, that?s a good thing to add!!
My B&C has right at 1000 hours and probably 2000 starts since most of my flying is local half hour hops.
Russ McCutcheon
Old 07-25-2011, 10:23 AM
Mel's Avatar
Mel Mel is offline
Default On the other side of the coin....
I replaced my starter with a Skytec HT in February of 1995 and it hasn't missed a beat!
Probably at least 2000 starts as well!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-25-2011, 11:45 AM
gasman gasman is offline
A B&C starter has the advantage of a lower power draw. A high power draw can pull the voltage of the battery below the requirements of some electronic ignitions and cause a kick back and maybe break the starter.
