  #11
Old 05-09-2006, 05:57 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default not sure
Originally Posted by BruceMe
The owner had his mechanic reset the silicon case seal. It's stopped leaking and I can go back to day dreaming while I fly.
-Bruce
Not afraid to ask, what does reset the silicon case seal mean? What seal? How did he "reset it". Thanks George
Old 05-09-2006, 06:54 AM
mlw450802's Avatar
mlw450802 mlw450802 is offline
I'm apoloizing up front with this post as it NOT intended to belittle but to clarify an all too common mistake on silicon/silicone usage.
Silicon is an element that is a major constituent of sand and a critical material used in the semiconductor industry and it is a somewhat brittle solid in its natural state.
Silicone is a compound class where the normally occurring carbon atoms have been displaced by silicon atoms. These range from light viscosity oily-like materials to the rubber-like compounds used for sealing and other things with which we are all familiar (Bay Watch, for example ).
Sorry
-Mike
PS George, this is not directed at you or anyone else. Your post was just a convenient opportunity for my response, so please do not take this personally
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 05-10-2006, 09:59 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Honestly... I don't really know. My gut says they loosened the case-seam up and gently presuaded the siliconE gasket/seal back into it's bead in the case.
After 5hrs, the leak is entirely gone now.
-Bruce
Old 05-10-2006, 06:09 PM
Default Thanks time's two
-Bruce
Thanks Bruce was not sure, thanks for asking and writing. Cheers George
PS: mlw450802 thanks I know, and no offense taken; You are 100% correct. However you're fighting a loosing battle, I am afraid, in the lexicon of English, Sili-CON or Sili-CONE is going to be miss used. Actually the common denominator is silica or silicon dioxide; (SiO2) a hard, glassy mineral found in rock, quartz, sand and opal. How about that for trivia!
It's like cement and concrete, two differnt things. Two totally differnt things but both have a common element. I gave up explaining long ago.
