Old 07-24-2011, 07:21 PM
CDBridgesRV7A CDBridgesRV7A is offline
Default Torque Wrench
Good Day Folks,
I'm looking at purchasing a torque wrench. What torque range should I be looking at? What is the max torqued bolt on the RV's? I just torqued 4 bolts on my HS and those were 20-25 in/lbs. Will there be higher torqued bolts later on in the build?
Chris
Old 07-24-2011, 07:39 PM
N9331v's Avatar
N9331v N9331v is offline
Got mine from Sears, goes to 250 inch pounds and don't cost much.
Ed Martin
Bluskydtl
RV7
DKB
Donations 1/19 & 6/19
Old 07-24-2011, 07:51 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Depending on what propeller you use, or if you plan on torquing bolts on or in your engine, you may need a wrench capable of torquing bolts in the 45-60 ft-lb range. It isn't something you'd need until you get around to installing your engine/propeller, but it's always good to keep a lookout for a good deal
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 07-24-2011, 09:07 PM
Av8torTom's Avatar
Default Beam wrench
I like the beam style wrench. Don't need to ever be calibrated, are less expensive, and you can monitor how much torque it takes to turn the nut on the bolt and add that to the final torque value. I have the Park Tool wrench. Got it on Amazon for $35. They make a 0-60 inch lb and a 0-600 (I think) model.
N677AT reserved
Superior XP O-320, 160HP
Old 07-25-2011, 10:17 AM
Steve Steve is offline
Default You may need 2 torque wrenches
I've got a 1/4" drive wrench for AN3, 4, and 5 size fasteners. I also have a 3/8" drive for the spark plugs - 35 ft-lbs or 420 in-lbs
Five Sierra Fox
RV-9A
Utah
Old 07-25-2011, 01:20 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Steve's got it right
The 1/4' drive in inch pounds (about 20 - 150) will get you through most of the build. Later on, you'll want the 3/8" drive in Ft/LBS.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 07-27-2011, 07:04 AM
ILikePike ILikePike is offline
Would any of the 1/4" torque wenches on ebay for $30-50 be worth having? I am looking to buy a smaller wrench for easier access. http://shop.ebay.com/i.html?_nkw=1%2....c0.m270.l1313
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 07-27-2011, 07:24 AM
curtis's Avatar
curtis curtis is offline
I would check out Harbor Freight. I bought both a 1/4" and 3/8" for approx $40. Both check good by the tool calibration lab at work.
RV-6A Slider
550 hours +
Build it light and cheap
