Old 07-24-2011, 03:27 PM
hcccs's Avatar
hcccs hcccs is offline
Question Oil pressure line - what material?
Is it OK to use a Aeroquip 303 hose in the engine comparment or do I have to choose a steel braided type?
Hans Str?hle
Jodel sold (SE-XEV)
RV-4, flying any day (SE-XJJ)
F?rentuna, Stockholm
Sweden
EAA222
2020 =VAF= $20 donation paid
Old 07-24-2011, 04:07 PM
mannanj's Avatar
mannanj mannanj is offline
Default Hose
303 hose is fine for use in the engine compartment but for safeties sake, you will want to cover it with "Fire Sleeve" a flame resistant covering. It is relatively easy to make your own hose using "491" fittings by following the directions. You will want to use a mandrel for each size hose to help make up the ends.
You don't have to use factory style bands on the ends of the Fire Sleeve to hold it in place, you can use several turns of safety wire wrapped and twisted around the ends to do the same job.
Be sure to seal the ends with RTV to prevent oil from wicking up into the Fire Sleeve insulation.
According to some, it wont be quite as pretty as braided stainless steel but the fluids won't know the difference. Your pocketbook will and you'll have the satisfaction of fabricating something else on your plane!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 07-24-2011, 04:34 PM
Pat Stewart Pat Stewart is offline
Default Hose
Not the area of the airplane to just be good enough. I am a firm believer in steel braided and fire sleeve on anything in front of the firewall.
Pat
Old 07-24-2011, 07:27 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Check the costs before you go to the effort.
These numbers are 3 years old now, but the savings were pretty low over just ordering a custom hose from an outfit like PHT -
http://www.vansairforce.com/communit...5&postcount=15
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-24-2011, 07:51 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Van's oil pressure hose (complete) is $18.75 - I know I couldn't build one for that!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-25-2011, 05:23 AM
Smile Dont know what-
the availability of braided teflon is in Sweden, but it makes a lighter assembly versus 303. And, it doesnt have a service life like 303 hose. Assembled properly (even with reusable fittings) and firesleeved, its service life is virtually unlimited, but inspections are recommended.
Tom
Ridgeland, SC
