Here's what I would do for an IO-320 install in a "7"...
Purchase the 360 cowl and mount, then order an Inertia Ring or just a heavy crush plate. The harmonic dampeners are no longer in production. Depending on your engine weight you will probably be looking more towards the heavy crush plate.
Catto has also changed design in some of his later props, make sure to check the new weights on his props.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
