Old 07-23-2011, 01:12 PM
Av8torTom's Avatar
Default Torquing question
I'm torguing the four AN3 bolts that hold the tie-down plate to the spar. I noticed 10 inch pounds is required to turn the nyloc nut on the bolt. Specs call for 20-25 inch pounds of torque, so I'm continuing until the wrench reads 30-35 inch lbs. (20-25 + 10). Does this sound right? Seems hardly tightened at all. Were I not using a torque wrench I would have tightened it quite a bit more.
Tom
N677AT reserved
Superior XP O-320, 160HP
Old 07-23-2011, 01:52 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
An interesting thing I've learn is that the torque wrench often keeps me from OVER tightening a bolt. As Vans says when you call "it really doesnt take much torque to properly set an AN3 bolt". I tend to think of it as a measured way not to snap the AN3 bolts in half.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-23-2011, 02:10 PM
Av8torTom's Avatar
Default Well
let's hear it for torque seal lacquer. Should know soon enough if things aren't staying put...
Thanks guys
N677AT reserved
Old 07-23-2011, 03:18 PM
jjconstant's Avatar
jjconstant jjconstant is offline
On AN3 bolts/nuts I noticed that when torqued "correctly", I could still rotate the combination of bolt/washer/nut in the hole with a wrench on either the nut or bolt. This is with a calibrated in/lb torque wrench. If I "over-torqued" by another 5 pounds, the assembly would not rotate on its own. I confess to having over-torqued by this amount to prevent rotation of the assembly due to vibration etc. I developed the (bad?) habit of torquing AN3s by tightening just enough to not rotate in the hole. Repeatedly checking shows this as 5lbs over spec.
Is this a problem waiting to rear its ugly head?
Always looking to learn...
Jeremy Constant
Old 07-23-2011, 04:31 PM
Walt's Avatar
Walt Walt is offline
Jeremy Constant
I don't think there is anything wrong with this, and in fact, I do it the same way myself most times. You'd be suprised how many bolts I find that are "torqued" with zero clamp up force because the bolt is to long and the "torque" was actually due to it running out of threads.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-23-2011, 05:21 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
If the extra torque is tightening the joint then you are putting extra stress on the bottom thread of the nut which is not particularly good. A bit more and the threads could deform or the bolt stretch slightly in that spot. Not good assembly practice....
Follow AC 43.13 and add a washer. Then the correct torque will work...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-23-2011, 06:51 PM
Default torque settings
Tom
I set my torques for the heavy side of the spec. So, an AN3 would see a torque value of 25 in/lb which would include any torque drag from the AN nut.
I don't see 10 in/lb on every AN nut.
Regards,
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
