Storage issue
Jeremy,
No matter where or how you store your fiberglass parts, consider this. Fiberglass continues to cure for many months. The "tips" [wing, H/S, V/S rudder etc] will tend to collapse inward unless they are supported. Without internal support, they will then cure in that new position.
When you go to install them, they will not want to lay up tight against the metal skins. I would recommend that you stuff the insides of all these parts with either old rags or wadded up newspaper. Stuff them to the point that it forces the surfaces apart slightly. This will ensure that they fit against the skins tightly, when it finally comes time to install them.
I live in SE Florida. It's hot and humid here, as well. My parts were stored in warehouse bay [no A/C or temperature control] They survived just fine.
Just my opinion and worth what you paid for it.
Charlie Kuss
