Old 07-21-2011, 01:18 PM
rv9aviator rv9aviator is offline
Default Blast tube question.
I have a cooling shroud around the fuel pump on my Lycoming 0-320 and would like to add a hose to help cool it. It takes a 2 inch scat hose. My question is: doesn't every hole you cut in the back wall of the baffling just lose that much more cooling to the cylinders. I already have a 2 inch scat hose going to the cabin heat on one side and the oil cooler is on the other side. I'm concerned about causing heating problems by adding another 2 inch scat hose. Thanks!
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 07-21-2011, 02:44 PM
kentb's Avatar
kentb kentb is offline
Default Hello Jim
2" is a lot of air for a fuel pump.
I have a 1 inch and no shroud and it work great.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 07-21-2011, 02:59 PM
I thought that too. The factory Piper shroud that came with the engine is what I have on it. I could always adapt it down to a 1 inch. I wonder why they went so big?
Jim Wright
