08-11-2011, 09:29 PM
Another option:
Heat Shield Mat, self adhesive
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
08-12-2011, 07:08 PM
I am running the mufflers in parallel for cabin heat on our 9. I have covered the bottom of the cowl with self adhesive heat reflective material from the auto parts store. The left exhaust stack seems to move so I have doubled the clamps on the hangars to try and keep the muffler from getting against the cowl.
http://i1105.photobucket.com/albums/...5/DSCN2575.jpg
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
08-13-2011, 10:05 AM
Originally Posted by rv9aviator
After the mods my cowl is doing OK but I am having a difficult time keeping the mufflers and tail pipes from moving around after a few hours. Right after I adjust the rubber hose hangers there is about 3/8 of an inch clearance between the back of the muffler and the cowl. After a few hours it will be down to 1/8 of an inch from touching the cowl. I sure wish there was a better system to support the exhaust than hose clamps and fuel hose. I bet it works OK with just pipes but the added weight of the mufflers may be the problem.
After reading a few reports of this, I've been pondering this myself. One suggestion I've read is to try flaring the ends of the stainless steel tubes provided by Vetterman. That would add some mechanical support, instead of just friction between clamped rubber hose and steel tube. I tried that; it makes it a lot harder to assemble the hose onto the tube. I don't like the idea of the relatively sharp edge of the flare biting into the tube ID, since with heat already trying to kill the hose, this could shorten the life even more. I'm going to try an ISO bubble flaring tool next. Bubble flares are used on some automotive brake lines, among other things. It may assembly easier, while still providing a mechanical "stop" for the hose clamp to lodge against.
Is your system mounted per Vetterman's instructions (one set of hangers to the engine, the other to the motor mount)?
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
08-13-2011, 10:28 AM
Find someone with a tool that creates the outward bulge just a 1/4" or so from each end.
Something like this but rounded instead of triangular
_______/\__
08-13-2011, 10:43 AM
_______/\__
That would be an ISO bubble flaring tool
Lars Pedersen
Davis, CA
08-13-2011, 11:01 AM
Originally Posted by vfrazier
I think Tony Bingelis provided a good solution that I used. Use some thin gauge aluminum sheet cut to size in the high heat areas and glue it down with a bead of RTV. Don't squish the bead flat, leaving about a 1/16" air gap between the aluminum and the cowling.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
08-13-2011, 02:25 PM
This is what I used after having delamination problems with the stuff I got from Van's . I did lay a coat of plybond down before applying this material . This may have been an overkill , is has good adhesive on the product already . You want to make sure what ever shielding is used is secure , when the one from Van's came loose it shorted between the alt and exhaust stack, could have been ugly .
"Miss-Jessi"
RV-8 N231AH
Allen Holcombe VAF962
08-14-2011, 11:21 AM
_______/\__
Ron,
The tool you are referring to is called a beading tool. Most of us have seen beeding done on the fuel filters we buy for small engines. Beading is also done for rubber coolant hose connections on our cars. You can find one here. See
http://www.earls.co.uk/earls/accesso...dingtools.html
http://www.aircraftspruce.com/catalo...s/ezbeader.php
Charlie
08-14-2011, 02:27 PM
Originally Posted by chaskuss
I wish you hadn't posted those links... more tools that I can't live without- there goes the budget
I've used (borrowed) a KD Tools bubble flaring kit, but don't own one. The beader looks like a better tool for this job.
Lars Pedersen
Davis, CA
08-14-2011, 03:12 PM
Grinding grooves into the stainless supports
Jim,
I found that grinding grooves into the stainless metal tube hangers before they are inserted into the rubber hose creates enough grip for the hose not to slip once the clamps are tightened. I made the grooves using a grinding wheel. It works well for me after more than 300 hours.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
