Old 07-19-2011, 05:49 AM
hydroguy2's Avatar
Default OSH camping/parking
I've spent 4years listening to ATCLive and monitored the EAA webcams while at work. This year, I flying in! So, I've read the NOTAMS, I watch all the "how to" videos, practiced my slow flight. Even some neck exercises to loosen up my bad C6-C7 problem to keep my head on a swivel. But one question I have:
Which sign do I hold up? HBC or HBP. I am camping but not next to my plane, we getting a travel trailer delivered and set up in camp scholler.
Old 07-19-2011, 05:56 AM
Walt's Avatar
Walt Walt is offline
For you HBP, HBC is for camping with your airplane.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-19-2011, 06:03 AM
Geico266's Avatar
Geico266 Geico266 is offline
Don't forget your departure sign.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 07-19-2011, 06:07 AM
hydroguy2's Avatar
VFR got it
Old 07-19-2011, 09:21 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Will HBP get you with the other RVs or should there be another sigh for RV parking????
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-19-2011, 09:33 AM
rleffler's Avatar
rleffler rleffler is offline
Jeff's team does a great job sorting out all the HBP parking area. The RVs will be together unless the area gets over run due to volume. The back end of the RV-10 area usally gets some other aircraft parked there after other areas fill up. Unfortuantely, there's no easy way to predict what ratio of vendor/model aircraft will be flying into OSH.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-19-2011, 12:11 PM
hydroguy2's Avatar
You going Mike? where are you sleeping?
Old 07-19-2011, 12:15 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
HBP will get 'er done. Everything gets sorted by type at the intersection and sent in the right direction. We put the -10s in their own area due to their size.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 07-19-2011, 02:35 PM
Spindrift Spindrift is offline
Default Question for Jeff or other ground crew
I'm flying in on Sunday with a friend, and we plan on camping. I have to leave on Monday, then return on Wednesday, but he is going to stay the whole time. To avoid having to haul stuff, the preference would be to in HBC, but how do I get back to the parking spot where the tent is, and will it be a problem to have a tent and no plane for 2 nights?
bill
RV7A QB kit -- sold and now flying in S. Africa
RV7 purchased flying
"A pilot just bides his time until his plane can take him away again, into the air"
-- Jake Grafton (Stephen Coonts, Flight of the Intruder)
Old 07-19-2011, 02:56 PM
Mike S's Avatar
Senior Curmudgeon
We are staying at a private residence------guy on the Jeep forum I am on offered it to us, after I mentioned that the Jeep build program was slowed down due to finishing the RV 10.
Mike Starkey
VAF 909
Rv-10, N210LM.
