Old 07-17-2011, 08:34 PM
Default Your Climb Rate is Incredible
I was out flying this morning - working on my landings, which have been pitiful recently. Anyway, I was doing stop and go's, and a C-172 joined the pattern on an upwind leg as I was touching down.
Once I stopped and applied power again, I saw him off my right shoulder and slightly behind. I figured he though he'd enter turn crosswind in front of me, but I was off the ground, to pattern altitude, flew the crosswind leg and turned downwind before the Cessna turned crosswind.
About that time, the Cessna pilot came on the radio and asked "Aircraft departing Cartersville, what type aircraft is that? Your climb rate is incredible"...
Made me feel good in my little 160 hp, fixed (cruise) pitch RV-6...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-18-2011, 04:54 AM
pierre smith's Avatar
Default Yep
We left Ocracoke after a 172 had taken off and we turned out over the ocean, keeping him in sight. As we passed him, my wife said, "Jees, it looks like he's going backwards!" She'd never passed another airplane in our 180 horse -6A.
Yep, you made the right choice, Kyle.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-18-2011, 06:35 AM
rv8guy's Avatar
rv8guy rv8guy is offline
atta boy Kyle
keep em humble!
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 07-18-2011, 07:50 AM
java's Avatar
java java is offline
We have quite a few RV's on the field here, so the controllers are familiar with them. Just yesterday, I'm cleared to take off for a straight out departure behind a 172 staying in the circuit, and the controller made a point of asking me to pass on the left (right hand circuits).
It wasn't really an issue... when I reached the 172 I was already about 200 ft above him and he was just turning cross-wind.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 07-18-2011, 09:00 AM
SteveinIndy SteveinIndy is offline
What is the max climb rate on say an "average" RV-6 or 7?
Old 07-18-2011, 09:27 AM
Flyfalcons's Avatar
Flyfalcons Flyfalcons is offline
I guess that would make sense comparing a heavy, four seat aircraft with a small, two seat aircraft.
Ryan Winslow
Old 07-18-2011, 09:50 AM
N941WR's Avatar
N941WR N941WR is offline
There are too many variables to give you a solid answer.
With the 180 hp O-360 in my -9, 3/4 tanks, and a climb prop, I could easily see 2200 FPM. With the climb prop I currently have on the front 1600 to 1800 FPM is possible.
When I had the 135 hp O-290-D2 I could hit 1800 FPM solo.
Also, a lot of this has to do with the airport elevation (~600 to 800? MSL for me) and the OAT?s. None of those figures were adjusted for a standard day or altitude.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-18-2011, 09:56 AM
I was just kind of looking for a ballpark figure. If you can do that with a 180 hp engine, I am kind of rethinking the climb performance I might get out of the design I'm putting together that is at the moment be planned with a 300hp engine. Granted, my design is heavier than an RV but still....very nice.
Old 07-18-2011, 10:13 AM
N941WR's Avatar
... I am kind of rethinking the climb performance I might get out of the design I'm putting together that is at the moment be planned with a 300hp engine. Granted, my design is heavier than an RV but still....very nice.
Weight is the killer! My plane was only 990 lbs with the O-290. With the O-360 I've jumped to ~1060 lbs. I also have the long wing, which helps a LOT!
Bill R.
SC86 - Easley, SC
Old 07-18-2011, 10:24 AM
Yeah, we'll be a lot heavier than that. The engine we are looking at alone weighs about half of what your entire plane weighed with the O-290 mostly because I decided to go with a diesel piston engine rather than one that runs on 100LL.
