Originally Posted by Geico266
To any of the RV-12 builders out there that have installed wheel pants, you need to buy these fairings. They are really looking good on the plane and in the set I bought. Good quality, paintable, trimable, & flexable. They will be easy to install, paint, and really give that finish look to the -12.
Great job guys! It was a pleasure renewing the friendship again. Sorry I missed you at beer call!
But real glad I got out of there at 1:00. rain for 200 miles going west.
The uniqueness of our cover is it protects against rain and salt spray by holding out water better than cotton, polyester, or cotton/polyester blend covers. But our cover is breathable, so it allows trapped moisture to escape, helping to prevent rot and mildew. Our cover is great to use on your aircraft as it is vapor permeable and highly water resistant.
Our cover is made from abi-laminate nonwoven fabric. The fabric is engineered to provide high strength for the rigors of covering exposed aircraft while providing excellent protection from the elements. Our cover material is highly water resistant and will not absorb and hold water when wet like fabrics made from natural fibers. Water can readily evaporate through our cover to reduce the potential for mold and mildew growth within. This material is washable.
Our canopy cover has an excellent strength-to-weight ratio and is a lighter alternative to most covers, our cover weighs in at about one pound twelve ounces or .8 kilograms with cover case. The barrier properties of our cover material block harmful UV rays and provide protection from a variety of chemicals and environmental contaminates.
Our cover material effectively blocks 99.8% of the sun's damaging UV rays that can fade interior and exterior surfaces of your aircraft.
Keep your aircraft cooler during warm weather by reflection sunlight.
Provide superior water resistance, while allowing moisture to escape.
Resist acid rain, bird droppings, tree sap and other forms of environmental pollution to keep your aircraft clean
Hold out more than 98% of dirt and dust particles that can scratch and damage your aircraft surface.
