Old 07-14-2011, 07:21 AM
caryr's Avatar
caryr caryr is offline
Default Exhaust Configurations
Vetterman crossover exhaust for IO360 with Superior Cold Air sump
What does "Superior Cold Air Sump" mean??
Is that any different than the normal oil sump with the intake tubes gong thru it??
I sent Larry V a note to ask if this will fit my std O-360 updraft carbed Lycoming, but I haven't heard back.
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
Old 07-14-2011, 07:49 AM
Paul K Paul K is offline
Default cold air sump
Caryr,
The difference is that in the traditional sump, the induction air helps cool the oil by having the air pass through the oil sump. This also warms the air and cost you a small amount of HP as now the air is thinner.
The cold air sump, be it Superior or ECI, is a bolt on "air box" that mounts below the oil sump and the induction air does not pass through the oil sump and thus stays cooler and in theory delivers more dense air to the engine and more HP.
Cold air sumps present some issues, mostly with room under the engine between the oil sump and the cowl. This mostly shows up when you install the exhaust system and does force you to use one type of pipes over the conventional pipes. For example, my ECI cold air sump dictates that I install Larry's 4 pipe system as opposed to a corssover system.
Other issues are my forward facing fuel injection throtle body. I had to build a snorkel and completely new air system. There is also cableing changes, cowl changes, etc. Thelist goes on.
Anyway, many have done it and Larry is your best source for solutions with the exhaust.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 07-14-2011, 12:39 PM
AX-O's Avatar
AX-O AX-O is offline
Looks like this. I did not know there was a difference in shape/area of the sump and it would cause interference with the standard exhaust. I had to reorder another set of pipes.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 07-15-2011, 08:05 AM
n615ks's Avatar
n615ks n615ks is offline
Default Vetterman Exhaust
Larry V knows all the engine/sump/intake configurations. I would suggest you work with him directly. I had no problem communicating with him at all.
He fabricated a (4) pipe system for my AeroSport IO-375 with cold air sump.....Perfect!! It's nice not having any major obstructions under the engine.
Unfortunately it will be some time before I hear any sound out of those four pipes.....
Bill Swaim
Slow Build RV-7 IO-375-M1S is installed
FWF done - Wiring & Panel Complete
Cowl primed - Prop & spinner done.
Windshield and the other 80% yet to go......
Going for a new 'slow build' record!
N615KS Reserved Bettendorf, IA
2014 Donation has been paid
Old 07-16-2011, 06:23 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
I gave Larry a call a couple of days ago to shoot the **** and for some info./ dates on his fly-in. Clint says, Miss Kathy and Larry are out of town till next week.
Thomas
Thomas Shpakow
http://www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
