Old 07-12-2011, 05:33 PM
eatenbyagrue eatenbyagrue is offline
Talking New Engine Photos! (now what do I do with it)
Just got some pictures in today of my new O-360 ECI build on the test stand.
Dual Pmags being installed...
It's been 8 months since I ordered the kit, apparently it took quite some time for ECI to deliver. Looks like I'll have it in the shop soon!
For those of you engine shopping, so far I can recommend working with Western Skyways. They don't come up on the usual lists of RV engine builders, but they provided a great price, have lots of experience and were good to work with while I was getting quotes. If you call em, ask for Eric Barker.
So now the question is how do I store it? They're going to get ready for long term storage per the Lycoming SB. Unfortunately I'm farther behind then I hoped to be and probably have another 18 months of building left (always the optimist.) I figure if it's wrapped in plastic with a couple of pounds of dessicant I should be good. Anything else I need to do?
Joshua Siler
RV-7A QB
Old 07-12-2011, 05:57 PM
Thumbs up
Looks great! I love yellow. You should order transparent cowling for it
Old 07-12-2011, 06:34 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Pickled
Don't know about "pounds" of desiccant, but once they pickle it, don't turn it over. Use desiccant plugs, regenerate the desiccant when it turns pink, and cover with plastic to keep it clean.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 07-12-2011, 07:56 PM
N130PM's Avatar
N130PM N130PM is offline
Is that an oil filter pointing down, toward a yellow engine?
Old 07-12-2011, 08:10 PM
ccrawford ccrawford is offline
Serious question: Does painting the cylinder fins reduce the heat transferred to the cooling air?
// corey crawford
// rv-7a (sold)
// denver, co @ KBJC
Old 07-12-2011, 09:01 PM
cjensen's Avatar
cjensen cjensen is offline
Love that engine!! I almost went yellow with mine, but my draw to red won over all. Seriously great looking engine!
Corey,
Most Lycoming cylinders are painted, even from the factory, they are "Lycoming Gray". I supposed if the paint wasn't engine paint, designed for high temps, and allowing heat to transfer, it could present an issue, but most folks do use the proper paint and have no issues. Continental's cylinders are typically not painted, but are alodined or bare metal.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
