Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 07-12-2011, 02:56 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Garmin 496 altitude 450 feet off
I've been flying with my Garmin 496 for almost 4 years now and the altitude readout on the instruments page always shows me about 450 feet higher than my altimeter says. I really did not pay any attention to that until a couple of months ago.
Is there a way to correct that? Anyone know why that is?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 07-12-2011, 03:21 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
How does the 496 altitude display compare to a known ground elevation when you are just sitting still?
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 07-12-2011, 03:25 PM
Walt's Avatar
Walt Walt is offline
GPS and pressure altitude are two different things, sit back relax and read all about it HERE
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-12-2011, 06:43 PM
gasman gasman is online now
I have a 2000C and I get upset when it gets more than 50 feet off.
And it never gets more than 100 feet off.
Old 07-12-2011, 06:49 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Pretty much the same here and it sure won't be a constant... 450 ft off all the time, something has to be wrong somewhere.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-12-2011, 07:33 PM
Wayne Gillispie Wayne Gillispie is offline
Default My 496
is always within 50' of altimeter too as I recall.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 07-12-2011, 07:54 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Then you don't fly to enough places...
When I reset my altimeter to a current pressure setting, the "six pac" page of my Garmin 696 & aircraft's alimeter will often read nearly exactly the same. The dials will just follow each other. This might last 10 mins or so..........considering there is variations with barametric pressure.
And once I've moved a bit on the ramp, the 696 also nails the airport altitude within feet. But I have seen variations of 200+ feet between the two, while in flight. If anything, the GPS is showing a more accurate altitude in regards to terrain. The altimeter is showing an altitude needed for ATC and seperation.
L.Adamson --- RV6A
Old 07-12-2011, 07:57 PM
Frank Smidler Frank Smidler is offline
Default 296 off 270 to 300 ft
I also noted the same issue with my Garmin 296. The other day it was very hot and at an altitude of 4500 ft the GPS showed a higher altitude by 270 to 300 ft. On the ground they both showed the correct altitude.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 07-15-2011, 01:54 PM
etekberg etekberg is offline
Your altimeter lies to you. It does not correct for temperature and it only is accurate when you are very close in altitude to the report station (the airport). The higher you are the farther it is off. When it is hotter than standard it reports lower than you actually are (a safe condition). When it is colder than standard it report higher than you actually are (a dangerous condition). That is why you will see notes on instrument charts that say Baro VNAV N/A below XX degrees.
GPS altitude is more correct, especially WAAS enhanced GPS.
Old 07-15-2011, 04:29 PM
Kevin Horton's Avatar
But the definition of "correct" depends on exactly what you are trying to do. If you are trying to measure the elevation of mountain top, GPS is almost certainly more correct than the barometric altimeter out of your aircraft. But, if you are trying to follow ATC's instruction to fly at 6000 ft, the barometric altimeter on your instrument panel will be much, much more correct than the GPS. Given that this forum is about aircraft in today's ATC environment, the barometric altimeter is the correct reference as everything is based on barometric altitudes.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
