Old 07-12-2011, 01:00 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default AlTrak install Pix?
Hi Folks,
I bought a TruTrak Altrak pitch control autopilot. I have everything except the install kit which TT says consists of a "bracket, pushrod, rod end bearings, bolts, washers, and nuts", cost $75. I am wondering what's special about this stuff as I have a close supplier of stuff like this (Van's).
Does anyone have clear pix of this install so I can see for myself? ...or thoughts/advice? jerry2dt@aol.com
Thanks in advance,
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 07-12-2011, 03:27 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Here's a link to pics of my Altrak installation Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 07-12-2011, 04:51 PM
Thanks Rosie, that helps a lot. Did that mounting bracket come from TT or did you fab it? It looks like the servo is held on with 3 of 4 bolts? How many wires need to go forward to the panel?
Regards,
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 07-14-2011, 02:15 PM
Rosie's Avatar
Regards,
Hey Jerry, the entire mounting kit came from TruTrak, and it had everything I needed except for the small bracket that holds the static-pressure sensor. Three bolts hold the servo to the bracket, and I believe there were 7 or 8 wires that I had to run from the back to the front of the plane (this was the most difficult part of the entire installation: knowing what I know now, I'd recommend for all builders to place a conduit during the build for future growth ;-)
I have more pics at home so let me know if you need anything else Rosie
Old 07-14-2011, 04:21 PM
Default TT Bracket
Thanks again, Rosie... But you know, it's kinda funny because I contacted TT and thought I'd just fab up my own parts because I have rod ends and stuff so I asked for a schematic of the bracket and was told that's proprietary. So then asked two days ago if they would just sell me the bracket and no answer so far. Very unusual because they have always been super responsive in the past.
I might have to make one up using your excellent pix...I hope I don't get sued for copying it though... Yah, I am kidding.
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 07-14-2011, 05:45 PM
Gerald Clabots Gerald Clabots is offline
Default Bracket
Jerry
Check your email
Old 07-14-2011, 07:00 PM
rv9aviator rv9aviator is offline
I would imagine this would be the toughest time of the year to reach most vendors as they are all up to their eyeballs trying to get everything ready for OSH. $75.00 isn't much money for not having to fab the parts and wonder if it will all work the first time. Good luck with the install! You will love the Altrak.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
