Old 07-11-2011, 08:55 PM
Cfrisella's Avatar
Cfrisella Cfrisella is offline
Default Static line testing question
Is it normal to see an increase in airspeed when testing the static system with a slight vacuum? I tested the pitot side and that is leak free and operating fine. When I pulled a vacuum on the static side both my GRT and Vans ASI show a speed increase. My first thought is a calibration task not yet performed or the system needs a positive pressure from the pitot, which it's not getting. Or I just hooked something up wrong. Most likely reason.
Old 07-11-2011, 09:04 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default That's normal
The airspeed indicator is really just a differiential pressure guage.
You changed the static pressure, so there was a difference between static and pitot!
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 07-11-2011, 09:42 PM
Cfrisella's Avatar
Default Cool!
I didn't think it was hooked up wrong. I've surprised myself before though. Thanks!
Old 07-12-2011, 01:36 AM
paul330 paul330 is offline
IAS is a function of dynamic pressure (P). When standing still, the pitot senses static pressure (S). When moving, the pitot senses P+S. Hence the need to subtratc static pressure from pitot pressure to get an accurate reading. The upshot is that any static errors will result in an IAS error.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
