Old 07-08-2011, 08:37 PM
brian's Avatar
brian brian is offline
Default How does inboard brake pad come out?
I need to replace the brake pads on one side of my RV. The first side was fine, but the other side definitely needs it.
But I can't figure out how to remove that inner pad (or remember how the brakes went together on the RV I was building).
I've got the wheel, rotor, and outboard brake pad off. I've removed the 2 nuts for the stud that the inboard pads rides on. But the stud doesn't seem to move at all, even after the nuts are removed. What job are the nuts doing?
Here's a pic:
Caliper is C, B is end of rod that the inboard pad floats on, A is where the nuts were. A-B appears to be one continuous threaded rod, but it doesn't move a bit when the nut is removed.
Is rod A-B threaded into the caliper and has to be threaded out(toward the left in this pic)? With pliers on end B? That doesn't sound very good for something I want to be smooth so the pad can float freely.
Do I have to remove the AN nut on the brake line and move the whole caliper inboard until rod A-B clears the backing plate? I hope not, as that'll introduce air into the brake line.
What's the magic trick here to get that inboard pad off the 2 pins A-B?
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 07-08-2011, 08:57 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Default No puzzle
No mirrors, no magic tricks.....you simply slide it off. I recommend a little lube on the slider bolts during assembly.
http://www.groveaircraft.com/iac.pdf
Edit - oh yea.....'if' you don't have enough slack in the brake line you will have to undo the fitting. You can pull the vent plug on the main reservoir and intall a pipe plug....this will prevent the fluid from running out.
Have fun.
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 07-08-2011, 11:14 PM
gasman gasman is offline
Here's a pic:
You are doing it the wrong way!!!!!! Put the nuts back on the studs.
Now look at the brake pad that is closest to the tire. That pad and plate is held on to the cyl with two 1/4" bolts. Use a 7/16" wrench and remove the two bolts. Remove the plate with the brake pad riveted to it.
Now, just slide the brake cyl out of the two dowel holes. Go easy and don't strain the brake tubing. Once the dowels are clear, then squeeze the plate with the other brake pad so the piston will retract back into the bore.
Now remove the plate and pad off of the dowels. When you replace them, be sure that the pads face the disc.....
Keep the dowels clean. They must slide as the pad wears. Bolube works good here. It is dry and won't collect dust.
On page 6
http://www.groveaircraft.com/iac.pdf PARTS LIST.. remove 14 with 12 by removing 2 #7 bolts only. Then the cyl will slide out of the holes. The dowels stay with the cyl.
Old 07-09-2011, 06:32 AM
Walt's Avatar
Walt Walt is online now
This is SERIOUS business, loss of braking can/will cause an accident.
IF YOU DON'T KNOW HOW TO DO SOMETHING FIND SOMEONE THAT CAN HELP YOU !!!
HAVE A QUALIFIED INDIVIDUAL INSPECT YOUR WORK WHEN YOU'RE DONE, ESPECIALLY IF YOU'RE NOT SURE WHAT YOU'RE DOING
The internet is a great thing, but its apparant you would benefit from some "hands on" assistance doing your first brake job!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-09-2011, 02:25 PM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Brake Pad Change
Ditto what Walt said! Changing pads is an easy, dirty job but you need to be able to do it right! Get someone to show you how to properly remove both pads and how to rivet new ones on. I have a braided line so my caliper assy comes off easier without disturbing the hydraulic system. Never heard that hint before about putting a solid plug in your reservoir to prevent fluid from coming out. If you're going to disconnect that fitting you'll probably end up bleeding your brake system. So, if you don't have all the equipment to remove & install new pads and possibly bleed the brakes, don't attempt it until you do. If you do, you'll be a possible accident looking for a place to happen!
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 07-10-2011, 08:00 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default service loop for brakes...
here is a shot for reference...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 07-10-2011, 12:01 PM
brian's Avatar
Default got it
Got it OK now. Thanks for the tips, guys. Now I just have to ait for the order from Aircraft Spruce to come in! ;-)
brian
Old 08-12-2011, 03:48 PM
prkaye prkaye is offline
I think I need to remove my brake pads on one side and clean and bevel the forward edge of the pads to eliminate a very loud screech I hear as the brakes close at low speeds/stopping.
I haven't looked in detail yet at this, and it's been a while since I assembled these... do I need to take the wheel off the plane to remove the brake pads?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-12-2011, 03:57 PM
Default Wheel can stay on...
The wheel can stay on to remove the brake pads. The outter comes off without any particular effort, the inner requires you to pull the pad assembly with the pins away from the pin guides to remove the pad... this will bend the break line as you pull it and reseat it... any pre-load to the caliper from the break line will promote break squeal.
Stephen
ORCA Flight
Race 771
margarita!
Old 08-13-2011, 08:28 PM
Stephen, do those instructions apply to the Cleveland brakes (the ones that came with the kit)? I just noticed that some of the discussion above seems to be about Grove brakes.
Phil
RV9A (SB)
Ottawa, Canada
