Old 07-06-2011, 10:45 PM
Mile High Relic Mile High Relic is offline
Default I need a "T" for my MAP hose
I'm installing a couple p-mags, and (hopefully) the last part I need to find is a "T" for the Manifold Pressure line so it can be connected to each p-mag.
Brad at E-mag pointed me to the McMaster-Carr website, and I have found a fitting that I think is correct in terms of dimensions, but as a buyer not a builder I thought double-checking with the experts here would be a good idea. The existing line is/was split to the MAP gauge and the former ignition, so I have a 1/4" ID line already there. The two lines provided with the p-mags are 1/8" ID.
Is a Polycarbonate fitting appropriate? It says the operating temp is up to 275F, which is more than the p-mags will take. It is part number 5117K26 if anyone wants to look here:
http://www.mcmaster.com/#5117K26
Anyone have any ideas where I can get something similar in quantities less than 10?
Any thoughts are appreciated.
Old 07-07-2011, 12:20 AM
gasman gasman is offline
If you have a section of line that you want to "T" off of, take it to your local NAPA autoparts.
Old 07-07-2011, 04:33 AM
Rick_A's Avatar
Rick_A Rick_A is offline
I bought a bunch of high quality nylon fittings and Tygon tubing from US Plastics (usplastics.com).
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 07-07-2011, 05:23 AM
Brantel's Avatar
Brantel Brantel is offline
NAPA, Advance, AutoZone etc carry packs of these fittings on the cheap!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-07-2011, 06:09 AM
Ironflight's Avatar
VAF Moderator / Line Boy
On the -3, we're using the same QD fittings that I use in the Pitot/Static systems - they are actually made for truck pnuematic air lines, so have pretty good environmental characteristics. I went from #3 cylinder to the Van's sensor manifold. The MAP sensor screws in there, as does a QD fitting. Then I took a piece of PMag's vacuum hose (fits perfectly in the QD), went ot a QD "Y", then two lines to the PMags.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-07-2011, 06:10 AM
AltonD's Avatar
AltonD AltonD is offline
Just where the aviation isle is. They will point you right to it.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-07-2011, 08:53 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Paul...sounds like you have a good set up.. you have any photos by any chance?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 07-07-2011, 11:19 AM
Ironflight's Avatar
You can see it in this pic - it's on the right side of the manifold. I didn't think this up - stole the idea from Doug Reeve's airplane.
Paul
Paul F. Dye
Old 07-07-2011, 11:20 AM
I was at O'Reilly aviation just the other day, but didn't think to look for this part there. I was looking at some terminals and wire, but ultimately decided to get that from Stein.
I've purchased some miscellaneous hardware from Ace aviation in the past.
I'll stop by O'Reilly on the way home.
