Old 07-05-2011, 07:28 PM
N601RX N601RX is offline
Default Sealing Lycoming IO 360 case halves
I would like to hear builders experiences with the 2 different methods of sealing the case halves. Silk thread or loctite 515? Also what gasket dressing have people used on the gaskets around the sump and accessory case and accessory case and accessories.
Old 07-05-2011, 09:43 PM
rocketbob's Avatar
I use proseal. It works extremely well. I will never do another engine any other way. And contrary to popular belief the sealed surfaces will come apart without too much effort as I tried on some test chunks of aluminum. I also used it on all gaskets that don't normally come off, like the sump and accessory case.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 07-06-2011, 10:56 AM
vfrazier's Avatar
vfrazier vfrazier is offline
I tend to agree with Bob on this one. ProSeal is great.
If you're concerned about "gluing" the halves too tightly, you can do as I did. Use the thread technique just like we have for years, then simply run a bead of ProSeal over the joints. You can paint over it and it will barely show as it self levels and smooths itself.
Seems to have worked fine and eliminated a few potential leaks.... goodness knows we have plenty of those on these engines.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
