Plenty of info (as usual) on this in the archives. Here's a link to one thread.
http://www.vansairforce.com/communit...vents+cracking
I recommend you read ALL posts in the thread and bear in mind that some comments are pure nonsense (like the suggestion to use lacquer thinner).
It's good that you struck this problem before you got to your canopy and ruined that !!!!!
I was involved in the manufacture of formed acrylic components. To clean acrylic I know that it is safe to use soapy water, or an approved specialised acrylic cleaner such as Plexus. If that fails I'll go to kerosene as a last resort. Nothing else.
Even substances that you might consider to be "mild" solvents such as methylated spirits can cause cracking of acrylic.
