Old 06-29-2011, 08:18 PM
dbaflyer dbaflyer is offline
Default T905 attach bracket close to rivet holes
Is this normal to have the attach bracket so close to the rivet holes here? It is hard to tell in the picture but it doesn't seem possible to dimple these holes and get a shop head to form without interference. This is for an RV9.
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 06-29-2011, 10:38 PM
flion's Avatar
flion flion is offline
I saw that on my -6A but not on the other models. However, it's not hard to deal with. Don't dimple the skin or the rib there. The thicker rib lets you countersink. Proseal and rivet the rib to the skin first and drive those rivets as much as you need to; you have extra strength with the proseal and the T905 has to get past those skin rivet shop heads. Now proseal and rivet the attach angle to the rib. It's worth your time to make a fillet of proseal along the inside of the end ribs and a smear of proseal over the rivets on the inside as well.
Another thing that may help (I can't tell from the picture) is to radius the edges of the bracket where it nestles into the rib, which can prevent it from resting against the rib web.
EAA Technical Counselor #5357
