Old 06-27-2011, 02:00 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Default Exhaust stack cleaning?
My apologies if this is deep in the search topics somewhere.
I'd like to remove the brown staining from the exterior of the stainless steel exhaust stacks. Not from the belly... that is easy.... from the stacks themselves.
Anyone got a secret technique or product that won't hurt the pipes, nor remove my skin?
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 06-27-2011, 02:12 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Vince, I have used a product called "Scrubs" made by Dymon Inc in Olathe KS. It is a polishing cloth for use on various metals. I used it to polish the stainless stacks on our KingAir E-90. Don't know if it is still available or not--we moved from the E90 to a Citation. The stacks on the 90 looked like chrome after polishing.
Skyking902001
RV-8 (in progress)
Old 06-27-2011, 02:20 PM
n504tw's Avatar
n504tw n504tw is offline
Default Intimidator
I've had good luck with Intimidator Micro-Diamon Pro Polish on motorcycle exhaust. Available at most truck stops.
Gary Hall
F1 Rocket Evo under construction
Track Links: APRS
Old 06-27-2011, 06:48 PM
rv9aviator rv9aviator is offline
Another couple of products that work pretty well are Blue-Away and Semi-Chrome polish. Both are sold in motorcycle dealerships.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 06-27-2011, 07:06 PM
gnuse's Avatar
gnuse gnuse is offline
Not sure what you expect the final result to look like, but WD-40 and Scotchbrite pads will leave a nice clean look.....not polished or chrome looking however.
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 06-29-2011, 11:52 AM
vfrazier's Avatar
Hmmm, Scotchbrite and WD-40 certainly meet my requirements for cheapness. And the others are reasonable too.
I was hoping for something like oven cleaner to remove the main "brown" and then follow it up with something to keep if reasonably bright.
I had found a few posts on other forums saying that toilet bowl cleaner, oven cleaner, various acids, etc. would work, but none of the posts seemed to claim actual experience.
Anyone else have any suggestions?
Vince Frazier
www.f1aircraft.com
Old 04-13-2015, 08:14 AM
bkthomps bkthomps is offline
Bump to see if there are any new ideas or success stories
Old 04-13-2015, 11:33 AM
turbo's Avatar
turbo turbo is offline
personally i like the aged look, 16 years old but would use any metal polish i could get my hands on.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 04-13-2015, 06:59 PM
g zero g zero is offline
Default Exhaust
Remove the system , buff with a sisal wheel and black compound .
Will look better than new , with about 2 hours labor .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 04-13-2015, 07:29 PM
BillL BillL is offline
No experience, but here is a supplier to the knife making industry. It has a lot of finer abrasives for our tools. 1000+ grit on stainless makes a nice finish. Nice 3M belts - even scotch brite belts.
http://user-a01k56j.cld.bz/CATALOG-50#109/z
Bill
RV-7
Lord Kelvin:
