Which size hinges do you guys recommend. I read that Mark Phillips used MS20257-3
I assume thats referring to the 1 1/4" as the Spruce MS20257P3-6
Or should it be 1/2" as the .04 metal strips?
Originally Posted by Richard Connell
And would do it again in a heartbeat.
Very clean and trivial to install/remove tips.
Wasnt too big a deal to install, maybee an additional 3-4 hours.
Only thing id recommend would be to use a wider hinge half on one side or the other so the hinge line is not visible.
Dont have any photos handy, ill take one next time i go flying.
cheers
