Old 06-25-2011, 04:44 PM
shuttle's Avatar
shuttle shuttle is offline
Default Tip: Computer image RGB colour matching to paint colour codes
Am trying to work out a good paint colour match for my upholstery and just came across this. Thought it worth sharing....
Given the RGB values of a colour on your computer, e.g. from a photo (easy to find using the 'pipette' then 'Edit Colors' in Microsoft Paint) this will offer up the nearest colour matches in a whole bunch of different paint colour coding systems.
http://www.easyrgb.com/index.php?X=SEEK
Obviously not 100% guaranteed, but pretty nifty.
Enjoy !
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 06-25-2011, 10:48 PM
Special Delivery's Avatar
Special Delivery Special Delivery is offline
Very convenient conversion tool... HOWEVER, if your monitor is not calibrated, what you see on your screen may not be close to the actual RGB color. One such tool for monitor and printer calibration is the Spyder.
Link to Sypder information >> HERE.
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
Old 06-26-2011, 02:31 AM
shuttle's Avatar
Agreed. One factor I hope is going to help me is that I do have a known paint colour with colour code. By working out the delta between the monitor RGB and the chart RGB for the known paint that may help me calibrate the monitor RGB for the colour I'm looking to match.
Steve Hutt
West Sussex, UK
Old 06-26-2011, 08:00 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The RGB values in hex of the Federal Std. colors from FS-595 is here -
http://www.fed-std-595.com/FS-595-Paint-Spec.html
It also lists the common names for the colors. These are the colors to copy for military paint schemes.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-27-2011, 01:45 AM
axlr8r's Avatar
axlr8r axlr8r is offline
Default Wow
Thanks Gil.
I've been looking for this info for quite a while.
Steve
Old 07-11-2011, 09:18 PM
Chunk's Avatar
Chunk Chunk is offline
Default Colors
If you see the exact color "in the wild" somewhere and have an iphone, there are several apps which will give you exact RGB values when you point your camera at it. Appzilla 2 is one that comes to mind (it's kind of a swiss army knife app).
Old 07-11-2011, 09:29 PM
PCHunt PCHunt is online now
Default T-6 / SNJ Yellow
Does anyone know which yellow was the official Navy color for SNJ's ?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 07-11-2011, 10:33 PM
az_gila's Avatar
Exclamation
This might help...
http://www.ipmsstockholm.org/colorch...rcharts_us.htm
and
http://www.alliancecoatings.com/warb...-1940-1949.php
Looks like it is "orange-yellow"
I believe this is one I picked for my sailplane and the DuPont dealer said it is also called 60's GM Schoolbus Yellow - not the modern, much more yellow school bus color...
A good reference here by service year... mostly still orange-yellow -
http://www.jpsmodell.de/dc/usn_e.htm
Gil Alexander
Old 07-11-2011, 11:01 PM
Default Thanks!
Gil, you are a treasure-trove of knowledge!
RV-6, RV-6A, T-6G
ATP, CFII, A&P
