Originally Posted by jimbo
Are these drawings to which Vlad and Pat refers large size (24X36 or similiar) or are they page size (8X11) when Vans sends them with the wiring harness kit?
I did call Vans and they emailed me a pdf but the drawings were so small you couldn't read them. When up sizing them I couldn't get any detail.
Jim
Jim,
I have OP 10 and OP 11 in PDF. I can blow them up about 300%. They are legable even at this size. The text for the side by side models in OP10 is blurry, even at 100%. I suspect that the sheet moved while the original was being scanned. I tried to contact you via email, but it appears that the email address you have listed in your VAF WWW account is no longer valid [or is being blocked]
Check your private messages.
Charlie
