This is a great question and I will be watching the answers in eager anticipation. I have an O-320 E2D in the same general condition that was higher time (1900 hours or so) but running well and came off a Skyhawk a few years ago for an upgrade to 180HP.
I pulled cylinders 1 and 4 on mine, and only pulled #4 because I couldn't see past the center bearing to check out the aft half with #1 off. Between those two it seemed I could see all the cam lobes and tappets pretty easily, but I don't know if there's a "preferred" or "best" way to do it. And when I had the jugs off I looked up inside at the condition of the head. No rust to speak of, good wear patterns on the exhaust valves indicating no leaks, machining still visible on the shiny cylinder walls, and nothing to catch a fingernail on the cam lobes or tappets. I put some new cheap auto engine oil in an oil can and coated the cam, tappets, and crank with it, just to make myself feel good about maybe an extra layer of corrosion protection. Then buttoned it back up and installed dessicant plugs while covering all other openings into the case and cylinders.
My plan is to go ahead and install this engine when my 9A is ready, then fire it up when it's time. I'll run it a few times on taxi tests and so forth before I take a compression test. Oil will be changed again right before first flight if everything looks and runs ok.
Hoping to get lucky and get a year or so off the engine before I tear it down. Of course at any time luck could change and I'd have to start budgeting for an overhaul before first flight.
Kurt W.
RV9A
FLYING!!!
