Old 04-27-2006, 11:05 AM
aparchment's Avatar
aparchment aparchment is offline
Default #6 countersink diameter in wing spar
Can anyone provide me with the measurement (in inches) of the diameter of a #6 countersink on the main wing spar? Mine are .3 so far, and my test skin with the #6 dimple doesn't quite fit into the countersink. The problem is if I go much further with the countersink I will be at the beginning of the radiused edge of the spar.
Thanks guys.
Old 04-27-2006, 11:34 AM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
According to Rudi's earlier post, Van's says they should be < 0.3125.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 04-27-2006, 11:59 AM
Thermos's Avatar
Thermos Thermos is offline
Antony,
There's also an article in the RVator a few issues back about this very question.
If you can't find it, let me know and I'll copy/fax it to you.
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 04-27-2006, 12:40 PM
aparchment's Avatar
Default thanks
Thanks guys. Dave a copy of that article would be great if you don't mind sending it to me. Would you prefer to scan and email it or fax it?
Antony
Old 04-27-2006, 09:47 PM
guy_deraspe guy_deraspe is offline
I have seen this rivet coutersunk diameter requirement somewhere before, but I always wonder how do you measure it down to +/- 0.001 inch? What measuring tool do you use?
Guy Deraspe
Old 04-27-2006, 10:31 PM
jcoloccia jcoloccia is offline
I used calibers. Since the countersink is round (presumably), orientation doesn't matter because you're always measuring the diameter.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
