06-21-2011, 08:49 AM
Phase II Operating Limitation
Hi Folks,
Finally here in Chile, the people that is building and flying experimental plane are getting together in one organization that is call ACAEX, We will be trying to change our regulation to FAA standard.
I want to know what kind of "operating limitation" FAA is issuing with your "special airworthness certificate" on phase II for your aircraft in the USA so we may ask to have same kind of limitation.
Please post copy of your airworthness certificate with limitation.
Fernando
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
06-21-2011, 09:21 AM
Fernando,
Here's a link to FAA Order 8130.2F Change 4
http://www.faa.gov/documentLibrary/m...7;20Ch%204.pdf
The info you want is on page 164, paragraph 154.
The companion verbiage in the FARs is out of Part 91, paragraph 91.319 and Advisory Circular 20-27g.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
06-21-2011, 10:23 AM
Originally Posted by Auburntsts
Thank you, that will help but there is one limitation here in Chile that we don't like it said:
"This aircraft do not comply with annex 8 from ICAO, so if you want to fly outside Chile, you must get a special authorization from the foreign country wish you pretend to overfly"
What we believe is that ICAO annex 8 do not apply to Experimental. Please correct me if I am wrong!!!
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
06-21-2011, 11:54 AM
This is on Page 25 of the above link -
(21) This aircraft does not meet the requirements of the applicable, comprehensive, and detailed airworthiness code, as provided by Annex 8 to the Convention on International Civil Aviation. The owner/operator of this aircraft must obtain written permission from another CAA before operating this aircraft in or over that country. That written permission must be carried aboard the aircraft together with the U.S. airworthiness certificate and, upon request, be made available to an FAA inspector or the CAA in the country of operation.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-21-2011, 12:44 PM
Gil,
I don't think Fernando is looking for the paragraph, instead I think he's asking if we agree with him that ICAO Annex 8 does not apply to Experimental aircraft as stated in the paragraph.
Fernando, unfortunately everything I can find on the AOPA and EAA websites points to the FAA's supporting the conclusion that Annex 8 does apply. The reason you might not find many pilots here in the the US complaining about it is our immediate neighbors (Canada, Mexico, and the Bahamas) have essentially given us US Pilots even with Experimental certified aircraft blanket approval to fly into and out of their countries with no additonal administrative requirements than a standard certificated aircraft (in the case of Mexico) or by simply having in our a posession a generic blanket form letter (in the case of the Bahamas and Canada) that anyone can download online ahead of time.
Here's the link for the Canadian authorization (note there's also an updated version for LSA's):
http://www.faa.gov/aircraft/gen_av/u...dia/tcauth.pdf
and for the Bahama's:
http://www.aopa.org/members/pic/intl...ATION_2011.pdf
So bascially this is a non-issue for the majority of US pilots. Perhaps someone with extensive experience flying internationally in their own plane will chime in.
PP ASEL-IA
WAR EAGLE!
06-21-2011, 01:00 PM
In Europe, that is essentially the rules... you have no "right" to fly abroad - and must get permission from each other country you wish to fly over.
In practice, as with the US, there are "agreements" meaning permission is not always required for each aircraft for each visit, for each country. But these are specific agreements, not "rights".
06-21-2011, 01:47 PM
Permissions...
Does this mean that in actuality we are required to have written permission from Mexico, Bahamas and Canada for example prior to flight into their airspace?
If so, does or has anyone done this routinely?
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/N1FLY
06-21-2011, 01:55 PM
We had the above referenced letter before going to the Bahamas recently.
Scott Card
CMW E-Lift
06-21-2011, 02:00 PM
For Mexico you already have permission, you don't need anything else as far as authorization goes (ie no need to contact the Embassy or some Mexican Gov agency to request permission). For Canada and the Bahamas, you are supposed to have a copy of the blanket authoriization letter on you, but I'll defer to those who have actually made those flights as to whether anyone has ever actually asked to see it. I plan to fly to the Bahamas regularly once I get in the air so my plan is to simply download a copy of the letter and put it with my other aircraft paperwork so I'll always have it. Will most likely grab the Canadian one too, while I'm at it.
PP ASEL-IA
WAR EAGLE!
06-21-2011, 02:22 PM
Oops
Missed the links above Scott...thanks
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Track N42AH/N1FLY
