Old 04-27-2006, 05:10 AM
NYTOM NYTOM is offline
Unhappy Fuel Tank Sealant Question
Would anyone out there know if that good old sticky & gooey tank sealant Proseal is compatible with the new sealant Van sell called MC-236-B2? Life got in the way of my 6A construction and forced a slight delay ( 5 years ) in construction with half of a tank already done with Proseal. And if not compatible, would anyone know where to get a fresh can of Proseal?
Tom
6A
N822PM (reserved)
Old 04-27-2006, 06:09 AM
tomcostanza tomcostanza is offline
My understanding is that they are the same. I wouldn't mix the two together in an uncured state. Or use the "A" component from one with the "B" component of the other, but I wouldn't have a problem doing 1/2 the tank with Proseal, and the other half with the newer batch (FlameMaster??).
Good luck.
PATOM
a.k.a. Tom Costanza
7A Fuse
Old 04-27-2006, 08:00 AM
ptrotter ptrotter is offline
All of the various tank sealants are basically the same as they need to meet the same mil spec. There shouldn't be a problem using different ones on the same tank, assuming one has cured before the other is applied. Van's seems to change suppliers periodically as evidenced by the picture in their catalog of Flamemaster's product, but the part numbers are AC Tech's part numbers.
Paul Trotter
Sussex, NJ
RV-8 82080 Finish/FWF Kit
N801PT
Old 04-27-2006, 11:57 AM
jarhead jarhead is offline
As stated already, if the products meet MIL-S-8802, they can be used on the same item interchangeably.
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
Old 04-27-2006, 03:29 PM
Talking Thanks for the help
Thanks Tom, Paul & Ken. That's what I was hoping to hear but you never know when it comes to different chemical combinations. I only got a chance to complete half of the job 5 years ago and was afraid I'd have to start with new tank pieces.
