06-20-2011, 07:14 PM
Different O-360 spark plugs
I have an O-360-A1F6D in my RV-4. It uses RHM40E spark plugs. Some of my RV O-360 friends have REM40E plugs. I see that the RHM is a 3/4-20 thread, and the REM is a 5/8-24 thread. Out of curiosity, why would there be two different thread sizes for an O-360?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
06-20-2011, 08:41 PM
They both thread into the same 18mm thread in the cylinder.
The thread sizes you mention are to the shielding on the plug harness.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-21-2011, 05:02 AM
Thanks, Gil...
Another friend pointed that out to me. I'm still wondering why there would be different shielding sizes...
Chris Smith
06-21-2011, 06:01 AM
The difference is in the sealing boot that goes into the spark plug cavity. The RHM is an all weather (completely sealed) which has larger sealing lip area at the barrel plug, and that?s why it has a ?? thread.
06-23-2011, 11:55 AM
I'm curious if anyone has ever noticed a difference in performance? I've never been able to see any distinct difference between the two. Makes me really wonder. Maybe on the bigger older engines that were more exposed to weather more often?
RV4 wing in Jig @ KPOC
RV7 emp built
06-23-2011, 03:18 PM
The RHM series or 3/4-20 "All Weather" design offers improved resistance to water (heavy rain) and improved flash over protection at high altitude - especially with the Slick Harness where the M-2928 insulating sleeve compresses the air as it is inserted into the spark plug barrel.
Typically, lower powered engines use a 5/8-24 threaded nut and larger, turbocharged engines, use 3/4-20 threaded nut. However, either one can be used. When replacing both the spark plugs and harness, consider upgrading to the RHM 3/4-20 "All Weather" as the price is the about the same. If you have an extremely tight clearance problem then stick with the REM 5/8 size.
07-12-2011, 03:24 PM
Autolite 2223
While we are on the topic of shielded plugs, I noticed that Autolite has a 5/8-24 shielded plug for air cooled military engines. It has 18mm dia, and 12.5mm depth, so it will fit. It has a cold Autolite heat range of '3'.
They cost $5.27 @ Amazon  aerospace . com
Has anyone tried them?
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
