It depends on how your LEDs are already wired. The following two circuits should give you a starting point. The diode type really isn't critical and you can expand the circuit as required ... I just happened to have this diagram around that shows three different kinds of displays. Adding four more diodes will expand it for seven indicators.
For indicators where the sensors switch the ground for the indicators:
For sensors that switch the positive side of the indicators:
If you have a mixed setup then you can add some extra electronics or the easiest solution is to just use a double pole TEST switch.
