Dave,
I have an M1B and a Vetterman exhaust.
I fitted it to the vertical section of the #1 exhaust.
(I do have a vintage undercarriage. Little wheel at the back, but from the look of your pic it should go on the vertical section of #1.)
The scat routing was a bit of a bugger, but the LAME who I had check the FWF came up with an elegant solution.
I have all the cowls off at the moment so I can send you a pic. including the scat routing tomorrow.
I also fitted a CO Monitor.
Dan has an Angle valve engine and the exhaust is quite different. How do I know. Vans sent me an Angle Valve exhaust in error and were so embarrassed that they sent me another straight away. Yes. I still have the other exhaust!!
Shall send the pics tomorrow.
Pete.
