Old 06-19-2011, 06:13 PM
Flying Scotsman Flying Scotsman is offline
Default Grounding strap location
With my close-to-stock battery location on the front firewall, it looks to me like the shortest run for that big grounding strap to the engine would be to the stud on the accessory mount for the vacuum pump (which I won't have). Anybody see any problem with that, or does it *have* to go to a crankcase bolt for some reason?
TIA!
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 06-19-2011, 06:36 PM
dedgemon's Avatar
dedgemon dedgemon is offline
Default thats fine
I've built two like that.
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
Old 06-19-2011, 08:10 PM
Greg Arehart's Avatar
Mine is in that location. Anywhere on the engine should be ok as long as there is electrical continuity.
greg
Greg Arehart
N 7965A
Old 06-19-2011, 10:19 PM
Thanks mucho, guys...then that's where it'll go!
Steve
Santa Clarita, CA
#8,000
Old 06-20-2011, 09:43 AM
JonJay's Avatar
JonJay JonJay is offline
The "per plans" location has you run the battery grounding strap to the firewall. The engine ground is ran from the firewall to the bolt hole in the case near the base of the oil dip stick.
I do not think it matters as long as you have a good solid appropriatley sized ground to both locations.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-20-2011, 11:30 AM
shuttle's Avatar
shuttle shuttle is offline
Default x2
Steve,
I have used the vacuum pad mount studs too (still building so no operational experience). I have the B&C/AeroElectric Forest-of-Tabs on the aft side of the firewall, hence two bolts showing on the engine side of FW. Seeing these bolts, I went for belt-and-braces and put two engine ground straps, both to vacuum pad studs.
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
