Old 06-19-2011, 09:50 AM
cdr.rschultz cdr.rschultz is offline
Question wing fairing weather strip attachment
Have had very poor luck with the adhesive attachment of the butyl wing fairing weather strip. Am using the 3M weather strip adhesive, but have failed on 3 different occasions to get a permanent seal. Have prepared the surface well and used alcohol for a final cleaning each time, but I'm definitely not doing something correctly? Would very much appreciate your thoughts and experiences on the process. Thanks much.
Old 06-19-2011, 10:19 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default try some gorilla tape
i have had good success using multiple pieces of the black extra strong 'gorilla' brand duct tape.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 06-19-2011, 10:37 AM
jjconstant's Avatar
jjconstant jjconstant is offline
I used the same 3M weather strip adhesive I think. Yellow gooey stuff. I removed the gap strip from the plane and then put the rubber onto the strip, bent the rubber to one side to expose the inside surface and stuck the nose of the tube in the gap and ran the bead of adhesive into there. Let it dry off the plane. Once it was dry I reinstalled the gap strip.
All that said, I think the main concern is that the end of the rubber doesn't come loose and start banging on the fuselage in flight. I know some folks that didn't bother with adhesive and simply put a rivet throught the end of the rubber into the aluminum gap strip.
Jeremy Constant
Old 06-19-2011, 10:39 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default No Adhesive
If you get the fairing to fuselage fit snug enough you don't need adhesive. The hardest part to get right is the underside trailing end. Mine seems to be doing well after about 70 hours.
Jim Sharkey
RV-6
Default wing fairing
do you apply the tape to the bottom only?
Old 06-19-2011, 11:29 AM
Default tape to the bottom
the fairings are much easier to handle with the strip firmly attached with tape strips on the bottom.
Stephen
ORCA Flight
Race 771
margarita!
Old 06-19-2011, 03:07 PM
Greg Arehart's Avatar
After mine came loose in flight (no adhesive) I used clear silicone and no problems in the ensuing 200+ hours. Best done after paint.
greg
Greg Arehart
N 7965A
Old 06-19-2011, 03:45 PM
Default wing fairings
Just wanted to say thanks to all for their thoughts and suggestions. With your help, the "fix" is in place cheers, bob
