Old 06-16-2011, 10:48 PM
tx_jayhawk tx_jayhawk is offline
Default Source for 3.5" or 4" Duct Flange?
All,
My oil temps are a little higher than desired on my O-360 RV-7A with firewall mounted SW oil cooler. I'm currently running 3" scat from the #4 cylinder to the firewall mount. I'd like to increase to 3.5" or 4" scat, but I am having trouble finding a duct flange that size (Spruce has only up to 3").
Any good leads? Would also be interested in feedback if others have done similar.
Scott
7A
Old 06-16-2011, 11:44 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
IIRC, the one on my 10 is 4".
Check with Vans.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-17-2011, 12:44 AM
scsmith scsmith is offline
I made my own 3.5" flange and had it tig-welded onto a short section of 3.5" tubing. I think Van's sells 4".
Nonstopaviation.com sells a 4" butterfly valve that you can control in the cockpit to adjust oil temps in winter. They describe a 4" flange, but don't seem to have one on their site. So they must assume you get it from Vans.
Try part VA-187 $15.50
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 06-17-2011, 05:39 AM
mburch's Avatar
mburch mburch is offline
Van's P/N VA-187.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 06-17-2011, 07:25 AM
jetrench jetrench is offline
Default 4" Duct Flange
Try Spectre Performance, part number 91489 is a 4" aluminum intake duct mounting plate $14.99
http://www.spectreperformance.com/#CATALOG.91489
