Old 06-15-2011, 05:53 PM
rv9aviator rv9aviator is offline
Default Need help with Transponder connector!
I need to add one wire to my Garmin GTX 327 transponder rear connector.
The connector is a Cannon connector but looks like any other 25 pin flat connector except instead of having screws to remove the shell it is a sheet metal shell with bent over tabs. I have no idea why it is made this way but looks like the only way to separate the halves is to unbend the tabs and take it apart. I guess I just need someone to tell me it's OK to unbend the tabs and proceed. Any thoughts would be much appreciated.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 06-15-2011, 06:14 PM
bharral bharral is offline
If you undo the connecting screws and clamps, you should be able to slide the connector shell back along the harness. You can then thread the new wire through the opening in the shell. Crimp on a new pin before or after threading through the shell (whichever looks easier). Then insert the pin into the connector body, slide the shell back up snug and secure,
Old 06-15-2011, 06:34 PM
Longez's Avatar
Longez Longez is offline
Default GTX327 Connector
Jim,
You shouldn't have to bend any tabs to insert a new pin/wire into your connector. I may be misunderstanding your comment, but to bend the tabs being pointed to with the red arrows in this picture (where the two halves come together) would dissassemble the connector in a manner for which it is not designed.
If you need to extract an empty pin (or install a new one), the installation manual (section 3.2) identifies the pin extractor, crimper and positioner you will need to use. Appendix B includes an assembly diagram for the connector and backshell.
For 22 AWG wire, you will need a M81969/1-02 extractor and a Daniels AFM-8 crimper with K13-1 positioner (or equivalent).
Let me know if you have questions.
Steve
Old 06-16-2011, 07:44 PM
Thanks, you guys are right on the mark. It slid back after taking the strain relief off. Got er done.
Jim Wright
