Old 06-14-2011, 11:26 PM
baisicrv baisicrv is offline
Talking Fuel cap o-rings black
Hi fellow RVers
I am cheap and would like to find replacement o-rings for the older fuel caps.My caps are old but work fine they just need new o-rings and Vans no longer supplies them.I have tried the search button but the black o-ring size still eludes me .Anyone have ideas except spending good gas money on new caps.
Old 06-15-2011, 12:19 AM
brian's Avatar
brian brian is offline
Most auto parts stores and some hardware stores have a variety of o-rings that you could try to match up. McMaster-Carr and MSC each carry a huge range of all types of o-rings. You'll need to measure your OD, ID, and thickness.
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 06-15-2011, 10:23 AM
Default o-ring
The problem is the o-ring is already stretched so I can not match up because I do not have the oringinal size.
Old 06-15-2011, 10:30 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Ace...
Take your cap to Ace hardware and find their O-ring section and try them on until you find one that fits.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 06-15-2011, 10:31 AM
Danny7 Danny7 is offline
talk to tom brink and see if these are the right ones
http://www.vansairforce.com/communit...ad.php?t=73240
nothing special here...
Old 06-15-2011, 12:11 PM
brian's Avatar
I'm not sure what constitutes an "old" or "new" cap, but my RV-6A was built in the early 1990s, so that's pretty old for RVs.
Here are the approximate dimensions of one of my o-rings:
OD: 1.955"
thickness: 0.207"
Old 06-15-2011, 11:14 PM
Default o ring
Hi Brian
Mine was built around the same time.Vans said if it is black it is older and no longer available.The new cap has a brown o-ring and that is available.
Old 06-16-2011, 06:35 AM
Vac Vac is offline
Current cap is Usher UD-3. Large O-ring is 2-235 sized Viton 75 (brown). Small o-ring is 2-012 sized Viton 75.
Vac
Old 06-16-2011, 11:05 AM
Default Black o-ring only
Please everyone
The brown o-ring is available!!!!
I want any info for the BLACK o-ring
Need the size or where to find.I would measure mine but it is stretched so hoping anyone has this info somewhere.
Old 06-16-2011, 11:18 AM
krw5927 krw5927 is offline
Can we ask why you're needing the black o-ring and the brown one won't do? The brown Viton rings are resistant to a wider variety of chemicals, but are known to be a little harder and may not seal as well in certain applications in very cold temperatures.
Just wondering if there's something special about the black rings that I'm missing.
Kurt W.
RV9A
FLYING!!!
