Originally Posted by albertaflyer
Hi, I have an o360 and an Mgl Xtreme EFIS to monitor engine parameters. I'm finding that the #1 cylinder CHT is reading about 100 deg. C lower then the rest. I realize that there will be some difference between the four cylinders but the other 3 only very a little compared to the #1. thanks for any info!
I had a single EGT read much different than the other 3 at ambient temperature and found that I had made a really poor crip on one of the
wires to the probe. A good crimp resolved the problem. Don't know if a
loose connestion could be your problem with the CHT, but it might be worth a look.
