Old 06-11-2011, 06:02 AM
bardample bardample is offline
Question Folding Elevator Rear Edge
I am about to bend the rear edges of my RV7 elevator. Is it preferable to place say a 1/4" dowell along the rear edge whilst completing the fold? I notice on a few sites some fellow builders have done so !
Old 06-11-2011, 07:55 AM
flion's Avatar
flion flion is offline
Yes, though I think 3/16" is what was called for. The dowel keeps the bend consistent and doesn't let you crush the trailing edge; you'll find you need a lot of pressure on the homemade bending brake to get the leading edge to lay down on the spar.
EAA Technical Counselor #5357
Old 06-11-2011, 10:02 PM
Thankyou for your advice. Jeff R Australia
Old 06-11-2011, 10:14 PM
jimgreen jimgreen is offline
There are lots of threads on this. FWIW I got good bends without using dowel.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
