06-10-2011, 02:38 PM
Correct mags? IO-360M1B
The Lycoming TCDS lists Slick mags 4371, 4370 as the right mags.
Other sources, including Vans, list 4373, 4370.
The only difference apparently is the lag angle, 25 degrees for the 4373 and 20 for the 4371. Any reason for the discrepancy?
If I go with a single Lightspeed in lieu of the 4370, which would be better?
Dave A.
6A build
06-10-2011, 03:22 PM
My left mag is a impulse coupled mag, 25 degree. For the right, I have a lightspeed plasma III. I have the IO-360-M1B. With this setup, I can start on either (I have individual toggles)
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
06-11-2011, 12:16 AM
Lightspeed mags
Hi Alton, is there any information about performance increase for your engine with the CDI ignition - Lightspeed Plasma III ? Can this increase be assessed as a % of more HP.
06-11-2011, 08:32 AM
Dave A.
6A build
I'd stick with the 25? lag, I don't think you'll have any reason to run 20?. The more timing, the better the top end power typically, of course this decreases your detonation margin somewhat, but I've not heard of this being a problem on 100LL.
RV4 wing in Jig @ KPOC
RV7 emp built
06-11-2011, 10:20 AM
Err... I think the lag angle referenced is in the impulse coupler, it has no effect at normal running speeds.
The engine is timed at 25 degrees for both magnetos.
The latest Lycoming data seems to show that either a 4371 or a 4373 is certified for the engine model.
http://www.lycoming.textron.com/supp...fs/SI1443G.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-11-2011, 11:52 AM
One data point
Dave A.
6A build
My IO-360 M1B from Mattituck came with
Magneto ? Slick w / impulse coupler
Model# 4371
plus one Lightspeed plasma II
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
06-11-2011, 06:20 PM
Good info
Thanks to everyone with the responses.
Gil, I couldn't find a recent Lyco bulletin earlier. Thanks for the SB.
I suspect I will stay with the 4371, even though it would be slightly more susceptible to a kickback and injury to a Sky-Tec starter.
Dave A.
06-11-2011, 06:49 PM
No data on the HP increase. I do know that I get a 10 RPM drop during a mag check when I turn off the mag. I get 100-150 when I turn off the plasma. The mag plugs are on the bottom. I do my run-up with the mixture pull back. Otherwise the mag plugs load up while I taxi. If I run full rich and then do the mag check after taxi, I get the 150-160 rpm drop. Klaus tells me to ignore the actual number: Does the engine run smoothly on the mag. Answer:yes, go fly.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
